Nowy producent z Francji ??
Postautor: ProScan » sob gru 17, 2005 12:48 pm
http://www.titanium-system.com
Dochodzą mnie słuchy, że jest to system PI z identyfikacją znaleziska.
Póki co, można oceniać tylko wygląd.
Pseudotłumaczenie z francuskiego na angielski
Postautor: ProScan » sob gru 17, 2005 8:05 pm
Impassioned for more than ten years, I have decided with the assistance of some friends, engineer, technicians, and other prospectors, to design a machine which could perhaps revolutionized the metal detection. It is true that since the Seventies very little development level on the fundamental powers of the apparatuses could be really modified, only gadgets without real effectiveness were added to the wire of time. We thus worked with an aim of being able to satisfy most eager among us, it is for that that we endeavoured to meet as often as possible between prospectors to be able to create a machine worthy of interest at the technological and practical level. I little henceforth to say that at the present time we achieved our goal. Our machine of share its technical specificities will have the right moreover to have the name "of technological projections". Who would have thought that a few years ago to be able to pass other the mineralisation and the different ones from successive metals which flood our ground, but also from being able to index them clearly? Today that is made thing, thanks to our range of metal detectors you can now discover new feelings and thus delight you by the lucky finds which can still be carried out at the present time. Let us continue to make our passion a dream... Your very expensive and devoted colleague of prospection
First of all as you will note it above the adonis is equipped with a large screen 128*64 pixels, which confers a great visual analysis to him. Its design made of this apparatus one of best designed hitherto in the category of the metal detectors. The power of detection of the detector lies quite simply in the fact that it works in pulsated induction.... As you thus include/understand it within sight of the reputation of pulsated induction it is insensitive with the ground effects and other waste mineral which can flood our ground. One of the major projections of the product it is that the adonis has a "True discrimination in pulsated induction" We are able to differentiate very precisely using libraries from objects and metals stored in memories, we can also analyze, index, record, compare like posting the various targets. Moreover discrimination will be as reliable as a "VLF". The adonis also lays out: - Of an infra-red port, for the exchange of programs as well as the exchange of the libraries of objects recorded by the user. - Of a helmet without wire to be able to detect and dig with complete freedom. - It contains also a small clock real time "with an internal pile of safeguard to very long autonomy, several years" which will enable him to post the hour of the detector without updating this last A each time the battery is removed. The must of the apparatus it is that the latter will be able to record thanks to this clock all the targets at the time of a detection at a hour given. We can thus locate interesting metal concentrations and to draw them on a software which will be available (in measurement or the prospector carries out straight lines on the surface of detection). - Into final it will be equipped with a port usb which will enable him on the one hand to download on official Internet site of the libraries of objects as well as programs and the handing-over at days of the versions of the aircraft, it will also be used for for the sendings of the data capturing on a ground. The apparatus is equipped with 3 powerful proccesseurs as well as several memories. Its disc of revolutionary detection still dopes its power and its precision.
Re: Nowy producent z Francji ??
Postautor: sunipla » czw lis 15, 2007 11:25 am
sunipla
Postautor: ProScan » czw lis 15, 2007 11:49 am
Dzięki.
Do tych testów (robionych przez producenta) nie przywiązywałbym najmniejszej wagi.
Zwłaszcza porównania z XLT są bez sensu (jakie nastawy XLT?).
Jak na razie urządzenie nie pokazuje nic, co usprawiedliwiałoby wysoką cenę (1500 Euro).
