Eureka !!!
FIND THE GOLD AND SILVER WHILE PRICES ARE HIGH!!! Up for auction is this White's Beach Hunter ID Waterproof Metal Detector. You will not find a nicer one anywhere!! It was used only once for a successful shallow water recovery and is no longer needed. It works 100% and ID's perfectly. Features include...
Dual Frequency metal detector providing optimum detection on the sand and in the water.
Operating frequency 3 + 15 (kHz)
Two Search Modes: Toggle between All-Metal and Motion Discrimination for easy pinpointing and versatility.
3 Controls - Threshold, Sensitivity, and Ground. Total metal detector versatility is all here!
Salt and Freshwater metal detector versatility for all kinds of beach hunting.
Drop-in "AA" battery system and battery test. 20 hours of hunting.
Detachable control box for hip mounting or chest mounting
Waterproof Piezo headphones
Waterproof to 25 feet.
Weight with batteries 5.7 lbs
The detector is in 9.5 of 10 condition with only a small scratch on the bottom of the coil cover and a few nicks in the foam arm cups pads, otherwise this detector is as close to new as you can get. This detector is perfect for beach and shallow water detecting in fresh or salt water and will properly ID targets located. Iron will light red, Gold and nickels will light yellow, and clad and silver will light green. In the pictures provided, the yellow light on picture is while waving a nickel in front of the coil and the green light picture is showing a quarter waved in front of the coil to demonstrate accurate ID. You will not be disappointed with this creampuff detector. Save hundreds over a new one, they retail new for $899.00, so here's your chance to own one for less!!
Potwiedziło się to, co jest napisane : " ...Szukajcie a znajdziecie ..."
5,7 lbs , nie nastraja optymistycznie , ale elektronikę można przymocować do paska a cóż jest lżejszego od cewki z wysięgnikiem?
Gopherus
